1920's Monarch laqthe
aww
Postby aww » Wed May 20, 2015 1:05 pm
Here is a picture of the lathe I use. Advertised in Popular Mechanics in the 1920's for $225. I bought it a few years back and stripped paint and shot new, also mounted the modern electric motor on top. The cast arches on the top are actually aluminum castings that I made by first creating patterns from wood and then sand cast. I tried to make castings that give the feel of the machine. The motor sits on a welded frame, pivoted, and uses it's weight for tension on the flat belt. It really has no issues and I use it fairly often. It sits in my 10' x 10' shed, floor beefed up to hold the weight.
Allan
unnamed (1).jpg (28.94 KiB) Viewed 11464 times
Re: 1920's Monarch laqthe
Postby bob turner » Wed May 20, 2015 2:14 pm
I like it. Unfortunately, Photobucket has lost my photos of the 11" Sheldon, but here is a distant shot of the 9" South Bend. I have everything - full collets, lots of chucks, taper attachment, etc. built Sept. 1944.
Postby bob turner » Wed May 20, 2015 2:19 pm
Oh - here is a better shot:
The drill press is Harbor Freight - one of their better efforts. I have one in each hangar, one in the home workshop, and one converted to a rivet machine.
The table is also Harbor Freight. Do not waste your money. It needs serious bracing to even be useful as a writing desk, let alone a work bench. And it is made of fiber board, mostly. Looks great, though.
Oh, yeah, speaking of COLA, there are a lot of my UP cars - 90% K-Line. Way ahead of their time.
aww
Postby aww » Wed May 20, 2015 2:27 pm
Nice Bob!
I just bought another drill press, a Ryobe, much prettier than my other one.
Allan
HHS
Postby HHS » Wed May 20, 2015 10:41 pm
My Craftsman 6" 101.212, and China drill press, and another Harbor Freight work bench.
And then my father cira 1953.
Hugh
JJS cir 1953 (640x492).jpg (228.09 KiB) Viewed 11353 times
Craftsman 101.212 (640x360).jpg (286.56 KiB) Viewed 11353 times
Postby bob turner » Wed May 20, 2015 11:38 pm
I always wanted one of those 6" lathes. They are so cute. Here is the 11" Sheldon - it has 2- railed a dozen locomotives, and made drivers from rough castings for others.
Postby bob turner » Wed May 20, 2015 11:40 pm
This one is an early 12" Atlas - I sold it on Craig's list for $300 to the first caller.
I had an early Atlas 6" lathe for a time - did not like it. Attempted to machine some live steam drivers - wound up on a 10" South Bend.
Postby Rufus T. Firefly » Thu May 21, 2015 7:45 am
One of my drill presses....
Wish I had had my camera with me, but a couple of weeks ago while up at an Amish estate auction there was another one of these, but then in the barn was a band saw that was all wood - blade and pulley to the motor appears to be the only metal parts (nails & screws...).
Postby R.K. Maroon » Mon Jul 10, 2017 10:28 pm
And another bump. Not sure about that spelling of lathe. Janet called me about a week before I left for Kansas City to clean out Allan's basement to ask me if I wanted his lathe. I will spare the story for now of how she and I managed to get the thing loaded into the van, but we all -- including the lathe -- survived it. After the summer layout project is over I will build a pedestal for it and get set up.
Postby bob turner » Mon Jul 10, 2017 11:00 pm
So I am not the culprit. Until very recently, all my photo posts were Photobucket. That means almost all my stuff is no longer accessible from this forum.
My 10-coupled are all hosted here - and they are high resolution. But I cannot imagine that I have saturated this place.
We are going to need some guidance from Bill.
Nice to see Allan's stuff again. It has a charm.
Postby R.K. Maroon » Thu Nov 15, 2018 6:50 pm
Per Jay's suggestion I am going bump and update a few posts. This one is an embarrassment: I have had Allan Wehrle's lathe in my shop for about a year and a half and still haven't set it up. Here is sits, with headstock and tailstock removed, as was necessary to get the weight down for loading it into a van for the trip from KC to DFW:
I have had to rely on my little lathe for what it will do and rely on friends for more substantial lathe work (you know who you are -- thank you!). I need to fabricate a stand -- I have rough plans and material but it is just a matter of priority.
Re: 1920's Monarch Lathe
Postby R.K. Maroon » Mon Jul 15, 2019 11:17 pm
I have finally made restoration of Allan Wehrle's old Monarch lathe a priority. Part of what stalled the project was the need for a suitable stand. A regular workbench places the lathe too high. I was going to build a stand out of dimensional lumber, as I have a lot of that sitting around. However, there was an old test fixture in my shop from a customer project many years ago that was heading to the recycle center when I realized that it had enough 8020 in it to build a nice lathe stand. Here it is:
The top is two pieces of 3/4" furniture-grade plywood that I salvage from a built-in entertainment center in my house when it get removed as part of a remodel. The bottom shelf is to hold the extra chuck and any other heavy or tall pieces. There are brackets for a low-height shelf just under the top to hold stock and maybe tooling. I may make this a drawer -- or not (under the life is short rule).
The odd stack of horizontal pieces at the bottom on each side is my way of getting the bottom side-to-side rails off the ground enough to get a pallet jack (which I have) under the stand to move the lathe.
For those who don't know what 8020 is, think "lab grade erector set". By good luck, I had enough --just enough really -- 8020 in the right lengths to get the stand built without having to buy anything but 5/16 countersink machine screws to hold the top on. I also learned that a chop saw will cut aluminum with no complaint (and cut it pretty clean too). Sometimes procrastination is a good thing. I have been planning to give away my chop saw (an old and very heavy Craftsman I no longer use) but hadn't done it yet. *sigh* -- guess I'll have to keep it now.
More to come
Postby R.K. Maroon » Wed Jul 17, 2019 5:07 pm
Here is the lathe bed after a good clean up:
Everything looks to be in good operating shape, with no signs of abuse or excessive wear. I will say that Allan did a nice job painting this. Very little overspray -- in fact, very little evidence that his paint job was a repaint. I don't know what color these were from the factory, but the paint has the look to me of a factory job.
The next step is to get this up on the stand while it's still light enough to be lifted by the available crew (my fellow club members) without a crane. Then the headstock and tailstock get remounted.
Postby Rufus T. Firefly » Fri Jul 19, 2019 1:20 pm
Sharp looking unit!
Postby Roy » Sat Jul 20, 2019 8:38 pm
Mmm...compound slide! One thing my little Unimat still lacks.
Users browsing this forum: No registered users and 58 guests
