This is almost unbelieveable, one can get whole ...
Postby J. S. Bach » Sat Mar 04, 2017 10:45 pm
...switchers GM/AN NW2s for about the same or even less on ebay:
http://www.ebay.com/itm/391715750902
I lost interest when it topped fifty.
Re: This is almost unbelieveable, one can get whole ...
Postby rogruth » Sat Mar 04, 2017 10:55 pm
That must be a very special drive. :roll: :roll: :roll:
rrjjf
Postby rrjjf » Sun Mar 05, 2017 7:49 am
Nothing special, All Nation chain drive. I prefer the AN skewed gear drives. AN had problems with the chain sprockets splitting. New sprockets are available but the gear drives never fail.
Postby rogruth » Sun Mar 05, 2017 10:49 am
Joe,
You mean at that price it is just a common drive? :roll: :roll: :roll:
stephen neill
Postby stephen neill » Sun Mar 05, 2017 10:58 am
Joe - Thanks for your comment. A good friend very much thinks the chain drive is better and he is pretty knowledgeable about this stuff, but not as knowledgeable as you. And I'm trailing fairly far behind both of you. Steve
rrjjf
Postby rrjjf » Sun Mar 05, 2017 4:39 pm
Stephen,
The chain drive is probably quieter than the gear drive but I do not mind the sound of the meshing gears They are not that loud and they do not fail. Keep them greased and they will outlast you. I have a good number of All Nation diesels with the geared drives and the BSME club layout in Baltimore has a set of F-3 units with the old straight gear drives from the late 1940s and they are still going strong. AN developed a simple and effective diesel drive.
Postby ScaleCraft » Sun Mar 05, 2017 4:59 pm
I have no chain drives in service. I may have some chain drive trucks in a box.
I like skewed gears, but straight cut (even earlier) with speedometer cable instead of Toyotata hose will absolutely settle loose ballast into place. Most of mine are straight cut gears.
rrjjf
Postby rrjjf » Sun Mar 05, 2017 5:21 pm
The seller of this mechanism makes a note in his listing that none of the sprockets are split so he is aware of the potential problem.
Postby Jay Criswell » Sun Mar 05, 2017 5:41 pm
There is an easy fix for the sprockets splitting but I've grown bored with posting photos and how to do it. Maybe we should trade geared units for chain.
rrjjf
Postby rrjjf » Sun Mar 05, 2017 10:31 pm
Jay,
I have repaired and replaced split sprockets on Weaver drives but why bother when the AN geared drives are available and never have failed me. I don't need more to do!
Postby Jay Criswell » Mon Mar 06, 2017 12:32 am
Joe,
I'm not talking about Weaver, CLW, or RC, I typically throw or give them away. I'm talking about a permanent fix to the AN chain drive.
Postby Rufus T. Firefly » Mon Mar 06, 2017 7:55 am
Jay Criswell wrote:I'm not talking about Weaver, CLW, or RC, I typically throw or give them away.
Throw some my way, Jay! I can use them in trolley freight motors, :wink:
If someone throws a stone at you, throw a flower at them. Remember to throw the flower pot with it.
Postby Jay Criswell » Mon Mar 06, 2017 11:47 am
RTF,
Most have 40" wheels. Can you still use them in this configuration?
Users browsing this forum: No registered users and 160 guests
