Is this the right frame for CLW PRR H10?
Dennis Holler
Postby Dennis Holler » Thu Sep 14, 2017 8:46 pm
I think this frame looks promising, any thoughts from those who have the CLW version? I posted on the other forum but I know most of you frequent both... Besides, you can feel free to post some pictures of the CLW 2-8-0 and the Saginaw 2-8-0, 4-4-2, and 4-6-0... :mrgreen:
Either way, let me know, did I get lucky or is it close but no cigar!
CLW 2-8-0 frame.jpg (255.68 KiB) Viewed 8271 times
Doorstop Rookie
Re: Is this the right frame for CLW PRR H10?
Postby bob turner » Thu Sep 14, 2017 9:03 pm
You got lucky!
Dennis Holler
Postby Dennis Holler » Thu Sep 14, 2017 9:04 pm
Thanks Bob!
I felt pretty good about it, but what are the odds?? I was looking at American Flyer junk and just happened to take a second glance and then started thinking, checking and comparing pictures... If nothing else, I thought I could use it.
Doorstop Rookie
Postby bob turner » Thu Sep 14, 2017 11:57 pm
You found that in an American Flyer pile?
The giveaway, from here, is the steel sides with the brass spring sockets. Not sure about the cylinder saddle - I can look at one of mine.
rrjjf
Postby rrjjf » Fri Sep 15, 2017 7:03 am
Carey,
I recognize the tail beam casting...CLW H-10. Looks like a couple of the spring haners are missing from the third driver set
Postby Rufus T. Firefly » Fri Sep 15, 2017 9:24 am
Dennis Holler wrote:I was looking at American Flyer junk......
I have got to start looking at AF junk more often now, :mrgreen:
Dennis Holler
Postby Dennis Holler » Fri Sep 15, 2017 10:37 am
You know, some of the most unlikely and best deals come when you find stuff miss labeled or as a throw in on the side. Plus it helps that I'm not smart enough the limit myself to one interest in trains.....
Doorstop Rookie
Postby R.K. Maroon » Fri Sep 15, 2017 12:07 pm
I have a built-up CLW H10 chassis that is part of a kit but no photo in my files. I will take one and post it but in the meantime here are a couple of pages from the instructions:
Note that the diagrams do not show a leaf spring assembly at all drivers. I don't recall if my chassis has them or not. More later.
Dennis Holler
Postby Dennis Holler » Fri Sep 15, 2017 12:24 pm
Hi Jim, For some reason, those images are no workie for me. I think my email is in my profile if they won't load. yes, any in process pictures you can provide would be great. Not sure when I'll work on this , but if anything need to fine info on it!
Doorstop Rookie
Postby J. S. Bach » Fri Sep 15, 2017 8:24 pm
Odd, my CLW H-10 does not have any spring hangers; I guess that the original builder did not care or was lazy thinking that they would be somewhat hidden. Note that I would never have noticed until they were mentioned here.
Postby bob turner » Fri Sep 15, 2017 9:39 pm
What captures your coil springs?
I pick up both polarities from the tender - I never figured out how to install those driver tire pickups.
Postby ScaleCraft » Fri Sep 15, 2017 9:58 pm
Dennis Holler wrote:Hi Jim, For some reason, those images are no workie for me. I think my email is in my profile if they won't load. yes, any in process pictures you can provide would be great. Not sure when I'll work on this , but if anything need to fine info on it!
Images work great on XP.
Postby J. S. Bach » Sat Sep 16, 2017 10:30 am
bob turner wrote:What captures your coil springs?
Mine is not sprung.
bob turner wrote:I pick up both polarities from the tender - I never figured out how to install those driver tire pickups.
Mine picks up one side from the tender, the other from the loco.
I got mine (#7676) in a trade for a three-rail engineering sample MTH H-10; my friend is three-rail and I am two-rail. Mutual satisfaction on both sides.
Postby bob turner » Sat Sep 16, 2017 12:45 pm
Yours may be Saginaw - cast bronze frame, cast iron drivers. Later CLW had plastic drivers.
The MTH looks accurate at this distance.
Postby bob turner » Sat Sep 16, 2017 12:48 pm
At closer inspection, both look MTH. The black one is not CLW or Saginaw, for sure. Nice models, though!
