E units Identity please
Postby Carey Williams » Sat Oct 21, 2017 4:35 pm
Hello all
Can any one identify a pair of E units ? ....please
Body seems to be brass ... cast pilot , back , under belly , thick brass frame older type of trucks and drive .... modified to 3 rail with tinplate couplers and flanges. Nicely painted and signed by artist "Buck Cleveland" ...from 2002 ..... each unit is 10 pounds and 18" long ....
Any help appreciated .
Re: E units Identity please
Postby rogruth » Sat Oct 21, 2017 5:41 pm
Look nice in the photos.
Erik C Lindgren
Postby Erik C Lindgren » Sat Oct 21, 2017 5:54 pm
Yeah those are sweet :D
Postby bob turner » Sat Oct 21, 2017 8:32 pm
Don't know for sure - but I am officially jealous. They might be Jack Raymus bodies - look for Adams & Son logo on the inner roof.
Postby bob turner » Sat Oct 21, 2017 11:56 pm
Not Raymus bodies. Note the difference in aspect ratio of those side windows. Here is mine - time to solder it together.
stephen neill
Postby stephen neill » Sun Oct 22, 2017 4:16 pm
These are quite different from the more common units we see. I have a set of Pamona Valley diesels that are in some ways similar. But only in some ways, and then only similar. Does anyone else have PV diesels they can compare to these? Are the ends truly a casting and not brass sheet with a casting soldered to it?
Steve
Postby Carey Williams » Mon Oct 23, 2017 1:01 am
Hello all
Thank you for your kind comments...I forgot to add the photo showing the artist's signature ... and the over all interior construction ....seems to be all brass sheets soldered together ...( way above my pay scale ....)
Steve I'll re check the back of the engines to see construction ..they are unique .
Postby Carey Williams » Mon Oct 23, 2017 12:57 pm
Hello all
I stand corrected ..the ends are flat brass and a thicker piece soldered in the center .... pilot appears to be carved/ machined / whittled ? out of solid brass ...so no castings on the body .... truck frames yes....
during the rebuild / repaint ...the engine was 3 railed ( center rail ... oh no !) .. tinplate wheels swapped out on the non drive trucks ..so it will be an easy switch back to match the drive wheels .
So did someone scratch build the entire engine and add old trucks ? ( which may not have been new at the time of the construction) .
Postby bob turner » Mon Oct 23, 2017 3:05 pm
Not a chance they were early Japanese imports?
