Steam Power...what to lube?
Postby Robert » Wed Nov 15, 2017 9:52 am
Similar topics are being posted, but I'd like some advice on what to lube on steam power specifically.
I'm really curious about valve gear and the occasional squeaks they produce.
I keep proper lube in my gearboxes and do not expect to be opening them up very often.
When I put a locomotive upside down in my foam cradle, I oil axle bearings, clean drivers, and most recently a bit of oil on anything else that's in motion during running periods.
rrjjf
Re: Steam Power...what to lube?
Postby rrjjf » Wed Nov 15, 2017 10:10 am
Robert,
That sounds about right. I use Labelle light oil on my mechanisms.
Postby Seaboard Air Line Fan » Wed Nov 15, 2017 10:27 am
Robert,
I do about the same thing, I also look for parts that get bent easily.
Another thing to look for is wiring issues that might occur whenever the engine is picked up, turned over. I wouldn't open an engine up just to check (thereby inducing more failures), but anytime stress is placed on a connector or wire (like connecting/disconnecting) that's a potential for problems.
One of my civil servant jobs was writing planned maintenance procedures for Navy electronic equipment, maybe I need to write some procedures for maintaining my locomotive fleet!
Things we looked at when writing procedures were:
1) Are you doing more harm than good...is it really preventing anything? There was a procedure to spray oil on an air filter on an AN/UYK-20 computer. The oil was getting sucked into the computer and causing problems and a mess. We also had a procedure to open and inspect the cabling inside the computer, as it turn out this was causing a ribbon cable to fail prematurely.
2) Use common cleaners and lubricants, keep the amount of hazardous material to a minimum. Settle on a cleaner and lubricant and stick to them (don't end up with a cabinet full of different materials). This was a must on ships as they needed to keep hazmat to a minimum for storage and disposal. We should do the same in our homes.
The biggest issue I have is cat hair. I can't seem to keep the rascals off my layout or stop them from shedding. As a result, there's strands of hair on the outer surfaces of the models and they also get wrapped around the axles. Over time it builds up and causes problems. Carpet lint is also a problem for those that have a carpet layout.
Postby Seaboard Air Line Fan » Wed Nov 15, 2017 10:28 am
One thing I find that squeaks is the draw bar, a drop of oil will help.
Postby bob turner » Wed Nov 15, 2017 1:51 pm
Valve gear can and will wear out without lubrication. I use SAE 30 on all axles, crankpins, crossheads, and valve gear pins. The pin that holds the eccentric rod to the crank will go quickly without lubrication.
Users browsing this forum: No registered users and 58 guests
