Things NOT To Do With Die-Cast!!!
Postby Seaboard Air Line Fan » Tue Feb 06, 2018 4:22 pm
I started a BPRC conversion on my MTH Railking NW2 this morning, that is until I noticed a slight bow in the diecast frame/chassis.
I tried to slightly bend/flatten it when my King Kongness started showing...SNAPPED right in half :shock:
I swear I didn't put hardly any pressure on it, but it was enough. Now I've got it sitting while the JB Weld dries to see if that will keep things together. There was a small cavity on each side where the diecast fuel tank fits so I filled it up with JB and screwed the fuel tank in place.
Hopefully between the JB and the fuel tank scrws (and the fact the fuel tank is now JB Welded in place) that will fix my "mistake" :roll:
I was thinking about drilling and tapping some flat brass until I saw the tank fit into those 2 cavities.
Lesson learned...leave diecast alone. Now I have to wait a day and still have to figure out where to put the on/off switch and charging jack, the 9.6v, 2000Mah, NiMh battery pack fits nice between the 2 vertical motors, but I might have to make the engine shell so that in pops off vice having 4 screws coming from the bottom.
What a dunce, I should have known better.
I would post a photo but I've already put it together so the JB can dry.
Re: Things NOT To Do With Die-Cast!!!
Postby 2railjon » Tue Feb 06, 2018 8:51 pm
BobD, just curious if it was a casting imperfection or zemac metal decomposition?
I had a very old MTH diecast Santa Fe calf and after a few years the paint and metal just started flaking off it.
I’ve never bought another diecast loco since. And I’m not the only one who has complained:
https://ogrforum.ogaugerr.com/topic/poo ... 7974228332
Postby Seaboard Air Line Fan » Wed Feb 07, 2018 6:39 am
Jon,
Didn't see any decomposition or bad casting of metal, just bad JuJu on my part for trying to flatten it out.
I bought it back in 2009. It's Seaboard road number 1410, MTH #30-2269-1 from 2006.
When it broke the first thing that popped into my brain was "Where do I get a 1/8" thick piece of brass big enough to replace this with?". Then I started thinking about how do I cut all the holes for motors, etc?
I actually have the engine frame, motors, and trucks back together right now, the JB Weld seems to be working.
I've installed the on/off switch and charging jack in the bottom of the fuel tank, where the speaker was mounted. The battery and receiver will go on top of the frame, but I need to open my Atlas F3 to see how I wired the motors (parallel or series) so I can do the same on this 2-motored engine. All my other BPRC engines are steamers which have a single motor, except my Williams E7 (2-motors) and Weaver RS3 (1-motor) but they use the BlueRail receiver board vice the Deltang receiver I'm using in the NW2 and F3.
It'll have to wait though, the weather is nice and I have a 9:00 tee time!!!
Postby Seaboard Air Line Fan » Sat Feb 10, 2018 9:54 am
OH NO!!!
I think the zinc rot has hit my NW2.
I removed the motors last night to lube their bearing surfaces and when I reinstalled them the lugs that hold one of the sideframes onto the front truck block snapped off. I'm sure I wasn't putting a lot of pressure on anything.
I super glued them back and they should hold as long as I don't bang it or squeeze the sides of the truck but it sure has left me not wanting to put the engine on the track now.
I saw a NW2 unpowered calf on Ebay for under $60. but I'm not sure if the chassis and truck are the same design. They should be but it's also from circa 2006 and might have the same issues.
Postby Tom Dempsey » Sat Feb 10, 2018 12:16 pm
Locally here I can get brass plate and bar from a metals vendor, they have the ability to water jet cut shapes very accurately. I asked them if they could duplicate a plastic chassis in brass and they said yes, bring it in. This might be something to investigate if you live near a big enough community to have a local metals vendor.
Postby 2railjon » Sat Feb 10, 2018 12:32 pm
Tom, that sounds like a nice asset!!!
Postby Seaboard Air Line Fan » Sat Feb 10, 2018 5:21 pm
Thanks Tom, great idea.
On the way home today I was thinking "I better make a pattern of the chassis just in case..." On my to-do list tonight!!!
The diecast chassis is 1/8" or so thick for the side sill. I have a part number ($15) but MTH wants an exchange. The chassis that is broken has been modified for Kadees and had the gap closed, don't know if they would accept it.
Really the chassis is nothing more than a flat plate with holes for the motors/trucks, this is where a milling machine would be nice to have.
Postby Seaboard Air Line Fan » Tue Feb 13, 2018 10:18 am
So, what type of brass would I need to get for the chassis plate, C260 or C464? I need a piece 3/16"x2-1/2"x10-1/4". I've found a few places online that sell brass but need to know what to order. Or is there another type that is easier to cut? The only thing I have is a Delta band saw as far as big tools and of course my Dremel. I do know someone who works at a machine shop so I could get him to trim things up and maybe drill some holes, although I do have a drill press.
Speedy Metals has what I need for around $25 plus shipping, but it's C360 brass, need to look up the differences!
rrjjf
Postby rrjjf » Tue Feb 13, 2018 11:12 am
Seaboard,
360 is free machining brass and is nice to work with and is probably the most common to be found. I have never used those other alloys.
stephen neill
Postby stephen neill » Tue Feb 13, 2018 11:28 am
Bob - Maybe I'm missing something here, but I suggest you send the broken frame and the $15 to MTH for an exchange. There is no reason for MTH to care if it has been modified; they aren't going to try to repair it; that's not the business they are in. And even if they did, what would they do with it, offer it for sale at the bargain price of $13 as an alternative to a new one at $15?
The reason MTH insists on an exchange is likely because they are also not in the business of providing frames for other peoples projects.
Also, keep in find that if you scratch build a replacement, it has to be a "perfect" fit in order to line up in every way with the other MTH parts.
Thanks to those offering suggestions; they may be useful to several of us on other projects.
This is my second attempt to post this reply, the first is out there in the ether someplace. So if the both eventually appear that is why. This has happened several times on this list (but not others); often enough that I routinely copy and save my replies so that I don't have to type them twice, or 3 times.
Steve
Postby Seaboard Air Line Fan » Tue Feb 13, 2018 11:47 am
Thanks Joe and Steve!
I would contact MTH but I’d rather have a flat brass plate than take another chance on a bowed die cast chassis. I can drill the necessary holes myself and probably take some of the slop out in the process. By slop I mean where the trucks mount, there’s almost a 1/16” difference between the diameter of the truck mount and the hole in the chassis on both ends. Whenever direction is changed I can see one truck move before the other, it’s probably a combination of hole being too big, gear slop, and differences in starting voltage of the motors. I can hopefully fix the holes when I drill new ones, doing something about the gearing and motors may be more than I want to do st this point.
Plus I have the necessary paint that should match the Chinese Red color on the engine.
Plus... I like doing stuff like this :D
Postby Tom Dempsey » Tue Feb 13, 2018 5:25 pm
On my current project I used 260 brass plate and 360 brass for the buildup pieces, silver solder works great with them both and they both machine well.
Postby sarge » Tue Feb 13, 2018 5:37 pm
Bob.
You might want to ahead and at least give MTH a shout. The more feedback they get, the more they might feel the possible desire to hold their supplier (Kadar) to some sort of expectation of quality. Probably won't make an impression, but remaining quiet about shit quality means you accept shit quality.
I think it bloody stupid not replacing the frame free as it was mismanufactured. In that scenario I would get why they would ask for the evidence to be sent to them first.
On the other hand, its just as moronic a policy to require a return in order to sell one to you.
Anyway, measure it and draw it before you return it if you want, just as an insurance.
When you get the new one, at $15 its a cheap pattern. A modern shop could scan it and water-jet or mill it easily enough.
Just for thought, of course.
Postby Seaboard Air Line Fan » Tue Feb 13, 2018 5:47 pm
Sarge,
After some thought I feel you guys are right. I'll probably need a new truck anyway so might as well get the chassis too.
I will make the pattern though, always good to have.
Postby 2railjon » Tue Feb 13, 2018 5:56 pm
I agree with what Sarge said!
