Twist Drills
Twist Drills
Postby up148 » Tue Feb 13, 2018 2:03 pm
Looking for information on better quality twist bits (#61 to 80) than the ones you find on EB or Micro Mark. Maybe they don't exist. But, some seem to cut much better than others from my experience. The ones I've got are sold old I don't know where I got them. They actually seem to work better than some newer ones I just got from Widget Supply.
I've heard Mcmaster-Carr drills are good quality.
Re: Twist Drills
Postby Jay Criswell » Tue Feb 13, 2018 2:54 pm
Butch,
Yeah, don't bother with drill bits from hobby shops or from online hobby related suppliers.
I buy a lot of tools and raw material from MC and I'm usually very satisfied. Having said that, I buy all my drill bits, and most of my end mills, from shops specializing in professional machinists. I'm lucky, there are quite a few shops around here. I think my favorite Is Johnston Industrial Supply. I would think in your business you'd have numerous suppliers available. If not, do a google (or whatever) search for industrial machinist suppliers in you area. I'm betting there will be a bunch.
Re: Twist Drills
Postby bob turner » Tue Feb 13, 2018 2:55 pm
Cleveland used to be good - and I have had reasonable luck with taps from Micro Fasteners.
Re: Twist Drills
Postby Seaboard Air Line Fan » Tue Feb 13, 2018 2:58 pm
I need some drills too, haven't bought anything from here but they appear to have what we need:
https://www.micro-tools.com/pages/search-results-page?q=drills
I also get screws and such from MicroFasteners:
http://www.microfasteners.com/catalog/products/MSCHBB.cfm
but they don't seem to carry anything smaller than a #56.
Re: Twist Drills
Postby Robert » Tue Feb 13, 2018 3:01 pm
I've bought drill bits from these people. They offer drill bits in several quality categories, and prices. The bits I bought have served me well, but obviously each users experience will vary depending on individual use.
https://drillsandcutters.com/
Re: Twist Drills
Postby sarge » Tue Feb 13, 2018 3:02 pm
Anything larger than microdrills cut better when they are properly dubbed for brass.
A machineshop worth its salt has a grinder and bit-jig. Take your old ones that don't cut anymore and have them both reground and dubbed.
If you have one of your own, the angle for brass is in Machinery's Handbook.
Then label the index "for brass only"...
Re: Twist Drills
Postby Seaboard Air Line Fan » Tue Feb 13, 2018 3:38 pm
I could kick myself for getting rid of mine (from when I was a draftsman). A friend of mine was starting off as a machinist and I was in electronics and didn't need it anymore (or so I thought).
My dad had one of those elcheapo drill bit grinders, but I never could get the hang of it and don't recall if it went down past 1/8"
Re: Twist Drills
Postby up148 » Tue Feb 13, 2018 3:56 pm
Lot's of good information guys and I appreciate it all. I'll do some looking around. Seems the small (micro drills) #61 to #80 are harder to find at some of these larger supply companies.
Jay, is the Johnston Industrial Supply located in Missouri. Found several locations in MO, but there website won't let me drill down ( :lol: ) in their website to get to the smaller drills.
Thanks Guys.
rrjjf
Re: Twist Drills
Postby rrjjf » Tue Feb 13, 2018 4:42 pm
I purchase USA made drill bits from McMaster Carr. I believe Cleveland is still producing drill bits in the USA. Cheap drill bits are not worth fooling with. I purchase the tiny ones 61 thru 80) in package quantities. Using an accurate drill press to drill holes with some cutting fluid saves a lot of drills even the cheaper ones. Hand drilling with a Dremel tool does not usually work out to well for me.
Re: Twist Drills
Postby Jay Criswell » Tue Feb 13, 2018 5:47 pm
Butch,
I don't think so but I could be wrong. Looking at their website and it sure looks like the same folks. Bottom line, I don't know. If there's a contact number give them a call.
What always gets me in trouble is their Starrett display. Everything Starrett makes.
Like Joe, I buy a dozen at a time. Actually cost less than the cheapo ones offered by hobby shops, most online sellers, etc.
Good luck,
Re: Twist Drills
Postby Seaboard Air Line Fan » Tue Feb 13, 2018 5:51 pm
Can someone post the most likely sizes of bits to use for certain common items like:
handrails
lifting eyebolts
handgrabs
stirrup steps
windshield wipers
and anything I might have left off.
rrjjf
Re: Twist Drills
Postby rrjjf » Tue Feb 13, 2018 6:06 pm
Seaboard,
I use a dial caliper to measure the mounting pins on a casting or turning and select a drill that is the same size or darn close. Too many variations in castings to give a definitive answer. When using older turned handrail posts going into a cast boiler, I will usually run a 0-80 die over the mounting pin and drill and tap the part where the handrail is going using a No. 56 drill bit.
Re: Twist Drills
Postby Rufus T. Firefly » Tue Feb 13, 2018 6:32 pm
Seaboard Air Line Fan wrote:Can someone post the most likely sizes of bits to use for certain common items like:
handrails
lifting eyebolts
handgrabs
stirrup steps
windshield wipers
Like Joe stated, too many variations in castings even from the same vendor at times. Better to just have lots of drill bits - 5-10 - of each size and then measure to know what to use.
Re: Twist Drills
Postby bob turner » Tue Feb 13, 2018 8:34 pm
I find #s 63, 56, 55, 53, 52, 50, 47,43, 33, and 30 are the ones I use the most. I sharpen my own drills by hand, including doing what Sarge suggests on #50 and larger. My articles from years ago all address that issue.
I sharpen taps too - a Dremel tool with cutting disc, a magnifying glass, and a steady hand are all you need.
The test for a sharpened drill - two equal curlecues coming out of the work, and the hole no bigger than the shank of that drill.
The rake angle for brass is very close to 90 degrees. You just touch the cutting edge with the disc.
Re: Twist Drills
Postby sarge » Tue Feb 13, 2018 9:08 pm
I'll hold you should get chips, not curly-cues. The spirals are only there to clear the swarf out of the hole.
I've seem more than one very talented machinist whack away at a piece of brass and have those curly-cues pull the chuck shank out of the spindle, snap the bit, ruin the piece and watch the chuck scuttle away across the floor.
People don't respect the drill and drillpress for the true machine tool it is, and running an instrument shop I'd say the drillpress caused more scrap and blood than any other powered tool (including bandsaws).
Users browsing this forum: Google [Bot] and 37 guests
