mixing ACC and Goo (or contact cement)
PRR Man
Postby PRR Man » Wed Mar 07, 2018 2:14 pm
I need to create a shock resistant bond for some items that I cannot solder. ACC joints do not reliably resist shock.
I've heard tell of some of you using ACC glue with Goo cement, but need to know more particulars about it.
Is it mixed together prior to joining? Is the ACC applied to the Goo surface before-during-after bonding?
I am John Galt.
Chris
Re: mixing ACC and Goo (or contact cement)
Postby Rufus T. Firefly » Wed Mar 07, 2018 2:31 pm
PRR Man wrote:I need to create a shock resistant bond for some items that I cannot solder. ACC joints do not reliably resist shock.
Film of Goo on the porous surface; CA on the other surface. Join together, they have a little party, sing a little song, do a little dance, and it's done.
Postby rex desilets » Wed Mar 07, 2018 3:39 pm
The "film" of GOO is the tricky part...
Postby Rufus T. Firefly » Wed Mar 07, 2018 5:57 pm
rex desilets wrote:The "film" of GOO is the tricky part...
Only for the ham-handed.....and there are even fine tip applicators for those individuals plagued by ineptitude and failed coordination due to their advanced age, decrepit condition, and with a diagnosis of dry rot.
Postby rex desilets » Wed Mar 07, 2018 6:42 pm
Have we met???
So, where does one obtain a fine tip applicator for GOO?
Postby Rufus T. Firefly » Wed Mar 07, 2018 6:58 pm
Have we met???
Was I referring to you? Did you feel singled out? Do you feel picked on? Do you need a puppy? Do you really have a diagnosis of dry rot or any other infirmities listed? Ok, no puppies for you!
Same place you buy Goo. There's a pack of plastic tips that are actually curved - 3 or 5 in the pack. For all I know you can get them, directly from Walthers. Wait......the tips that I sell for CA that are about .3mm ID at the tip work.
Postby Tom Dempsey » Wed Mar 07, 2018 8:46 pm
I use special wooden ones from a toothpick container.
Postby rex desilets » Thu Mar 08, 2018 12:24 am
Rufus T. Firefly wrote:<snip>
Have we met???
By inference...
No, other than comradeship of others of my advanced years
Nope. Had one that grew into a highly independent German Shepherd, who regards me as somehow her servant
Maybe not dry rot (?). Otherwise, yes.
<snip>[/quote]
Postby up148 » Thu Mar 08, 2018 8:50 am
Have we met???
Retirement seems to agree with you Rufus. :D :D :D
Postby rex desilets » Thu Mar 08, 2018 12:09 pm
Hard to see if there is a difference....
aterry11
Postby aterry11 » Thu Mar 08, 2018 12:19 pm
You forgot to mention the most important part, Be sure to get it positioned correctly the first and really only attempt you will get with out major troubles.
Postby Rufus T. Firefly » Thu Mar 08, 2018 2:23 pm
up148 wrote:
rex desilets wrote:
Have we met???
Perhaps, Image
Although cutting up the pine tree that was uprooted in the last storm was sort of disagreeable, yet the trusty Stihl reduced it to something manageable, :mrgreen:
rex desilets wrote:Hard to see if there is a difference....
There are none so blind as those that refuse to see other than that which they choose to see.
And, those puppies are definitely not headed your way.......time for a new coat!
Postby Rufus T. Firefly » Thu Mar 08, 2018 2:27 pm
aterry11 wrote:You forgot to mention the most important part, Be sure to get it positioned correctly the first and really only attempt you will get with out major troubles.
Truth!
PRR Man
Postby PRR Man » Fri Mar 09, 2018 2:08 pm
Thanks Mates for the help, and snarky repartee.
Apologize for the delay back here. Been without power, phones, DSL days from the storm... due to a generous gesture by my neighbors tree cracking in half and yanking everything off the house.
Feels like the 70's again
I am John Galt.
Chris
Postby Rufus T. Firefly » Fri Mar 09, 2018 2:55 pm
PRR Man wrote:Thanks Mates for the help, and snarky repartee.
Good to hear you are ok up there in NJ!
Users browsing this forum: Google [Bot] and 43 guests
