1939 /40 NYC World's Fair cars
Postby Carey Williams » Wed Apr 04, 2018 12:34 pm
Hello all
1939 World's Fair O Scale layouts were cutting edge 2 rail operation ... 8 Eastern Railroads pooled funds for the displays and the Models were lettered "Eastern Railroads" as not to show favoritism to one specific railroad. The trains were to run 8-10 hours daily racking up some real mileage . A number of folks were involved supplying engines and rolling stock for the layouts ( Walthers, Alexander & Icken , etc) .
I was very fortunate to be able to pick up 6 freight cars used on the layout ... unique operating couplers, trucks with ball bearings, cast aluminium bodies. and a resistor from one side of the truck to the other...what's that for ? .
It has been written that the cars were only lettered on one side .....not mine ... lettering on both sides ..mixture of decals and hand lettering
There were some 200 freight cars purposely for use on the layouts so many more must be out there ...robust construction of the cars
will assure at least another 80+ years of survival .
I know of a few more cars out there in the world ....any engines from the layout out there ?
Thank you
Re: 1939 /40 NYC World's Fair cars
Postby Tom Dempsey » Wed Apr 04, 2018 12:37 pm
Carey Williams wrote:and a resistor from one side of the truck to the other...what's that for ? .
Some sort of analog signaling system perhaps?
Postby ScaleCraft » Wed Apr 04, 2018 12:54 pm
CTT someone once explained.
Now, I have no idea what was normal in these cars as far as decoration.
But, if My example is correct, then the tank car you show may have been repainted/relettered.
As you can see, a whole lot more lettering, even giving building, who made it, ball bearing trucks. Mine only has shunting resistor on one truck, and does have the claw couplers.
Postby Carey Williams » Wed Apr 04, 2018 1:47 pm
Hello Dave and Tom
thank you for your response ..Dave very nice car ... yes your's has a lot more lettering than mine ...
Tom ...the layouts were fully signaled ..by Crawford E Staples ..... who built a full line of signals ..quite lovely and well detailed .... the base was plugged into a radio tube socket ...for wiring clever !! they offered a full range of most the major style signals out there .... also signal bridges ..if you had money they had signals ... 1938-40's ..
their work is nothing short of fine art for the signal world ...
I'll post some photos later.... one day I'll have them on the layout ....figuring out how to wire them up ..now that is a different story ...
cheers carey
Postby Chris Webster » Sat Apr 07, 2018 6:39 pm
These are really fascinating photos.
What keeps the current from flowing thru the wheelsets? Are the axles made out of wood?
Postby Tom Dempsey » Sat Apr 07, 2018 7:53 pm
Those axles would have to have been insulated in order for the resistor to signal anything at all.
Postby Chris Webster » Sun Apr 08, 2018 10:58 am
Tom Dempsey wrote:Those axles would have to have been insulated in order for the resistor to signal anything at all.
I understand that; I just can't see how the axles are insulated. The resistors are connected to the truck sideframes, so we know that the sideframes are carrying current. The sideframes are held on by metal screws, which would conduct current... but it looks like there are fiber washers under the screwheads, so I assume that's how the sideframes were insulated from one another.
What prevents the current from flowing thru the wheelsets? My understanding is that plastics weren't common back in 1939!
Postby ScaleCraft » Sun Apr 08, 2018 12:06 pm
Phenolic.
Bakelite.
Varnish.
The steel wheels are on brass hubs, on steel axles....but....there is a varnish bloom on one side of the axle visible on my sample.
Sideframes are insulated from bolster.
Users browsing this forum: Google [Bot] and 43 guests
