Model under Contruction I G N (MP) #896 Dome
cole7015
Postby cole7015 » Thu Apr 05, 2018 9:22 am
This is the final series on this model. Painting decaling and lighting. The building portions was dealt with
back in August 2017. viewtopic.php?f=10&t=17163&p=323098&hilit=Mp+dome+coach+build#p323098
More coming soon
Bill Basden Delta Models
cole7015
Re: Model under Contruction I G N (MP) #896 Dome
Postby cole7015 » Fri Apr 06, 2018 7:47 am
OK here is the beginning of the painting photo's. main car body painted interior light gray main walls light yellow ceiling,
I like to do the ceilings this way makes the lighting look warmer ---- very small LED's and exterior colors Eagle Blue
with Eagle Gray Floquil paint has been clear coated with Crystal cote ready for decals and striping. Buff yellow and
brushed silver strips from Line O Tape. all painting done with Passahe series H air brush.
Bill Basden
Erik C Lindgren
Postby Erik C Lindgren » Fri Apr 06, 2018 9:01 am
My goodness what a masterpiece
Postby 2railjon » Fri Apr 06, 2018 6:05 pm
WOW!!! :D
Postby R.K. Maroon » Fri Apr 06, 2018 7:13 pm
First-class work as always, Bill. Thanks for sharing.
Thanks especially for sharing the tip about painting the interior roof pale yellow to warm up (and diffuse, I imagine) the light from the LEDS. Neat and simple trick. In the old days of course a lot of passenger kit cars had wood roofs, and if you left them unpainted, that would have worked too. But no LEDS. I have some cars with hand-made strings of grain-of-wheat bulbs, but those power-hungry Walthers tube bulbs were more common, or (worse), big incandescent flashlight bulbs stuck up through the floor. I like preserving old models but I will upgrade lighting with no remorse.
cole7015
Postby cole7015 » Sat Apr 07, 2018 9:03 am
Here is more photo's of the Seating and mural modules for the Dome short end. I make modules and use 1.4 MM sheet metal
screws to mount to the side angle soldered to the car side. this makes it easy to work with, all my cars are done this way.
The sub floor and walls are done using .016" brass sheet and soldered together.
The murals are made by using unique landscape photo's scaled down to be 2x3 feet and printed on gloss photo paper.
them mounted to mirror card stock and trimmed to represent a metal frame. the seatin parts are cast resin from our
extensive parts line.
I do not use any figures in my cars, because most on the market are over and under size.
Bill Basden Delta Models www.deltamodelsusa.com
Postby Robert » Sat Apr 07, 2018 9:20 am
Really fine model work and the attention to detail we modelers admire.
cole7015
Re: Model under Contruction I G N (MP) #896 Dome more photo's
Postby cole7015 » Sun Apr 15, 2018 6:41 am
Here are some painted and decal ed Dome body with all stripping and lettering the silver is brushed aluminum
stripes from Line O Tape. This saves hours and looks better than decals, mainly used for model cars.
All painting has now been completed, next step is window material for the car body and dome section.
then the lighting installation.
Bill Basden Delta Models deltamodelsusa.com
Bob Anson
Postby Bob Anson » Sun Apr 15, 2018 9:00 am
super work Bill, those seats look like the same ones Pantera sold at one time.
Bob Anson
Postby 2railjon » Sun Apr 15, 2018 9:49 am
Amazing work! Thank you for sharing!!!!
Postby bob turner » Sun Apr 15, 2018 10:41 am
Beautiful. Let us know how you attach glazing in that dome - I have a couple that need new clear windows.
cole7015
Postby cole7015 » Sun Apr 15, 2018 8:28 pm
Thanks for all the nice comments.
Here is some more photo's that are finished painting
ready to screw in to there proper location. One they are screwed into there sub assembly
you will understand why they are painted like they are. the window glazing is .030" thick
lexan sheeting and epoxy to the walls.
Sorry board quota data has been reached 7 new photo's did not load
cole7015
Postby cole7015 » Sun Apr 15, 2018 10:52 pm
cole7015 wrote:Thanks for all the nice comments.
Postby De Bruin » Mon Apr 16, 2018 12:11 am
Bummer, guess we'll have another "culling" too.
I got so sick of this I decided to use Photo bucket and and just post the links instead. Not that Photo bucket is good or easy to use, but it beats the aggravation with the memory storage here.
cole7015
Postby cole7015 » Tue Apr 24, 2018 3:50 am
Bob Anson wrote:super work Bill, those seats look like the same ones Pantera sold at one time.
Bob Anson
Users browsing this forum: Bing [Bot] and 43 guests
