on trainz site
Bob Anson
on trainz site
Postby Bob Anson » Fri Apr 20, 2018 2:14 pm
So I'm seeing a number of Joe Fiore's stuff on ebay, Southern Keystone. Bob Anson
https://www.ebay.com/itm/Overland-0701- ... SwGh5a2VOA
Re: on trainz site
Postby E7 » Fri Apr 20, 2018 2:45 pm
Looks like a nice model that has taken some abuse.
Re: on trainz site
Postby up148 » Fri Apr 20, 2018 5:36 pm
This will be an interesting item to follow. These are really worth some $$$ and the damage I see can be typical. I sold one with only one leg bent, while this one has all four bent. Whoever removed it from the layout was a gorilla... :( :( :( :( :(
Re: on trainz site
Postby Rufus T. Firefly » Fri Apr 20, 2018 5:50 pm
up148 wrote: Whoever removed it from the layout was a gorilla...
Sadly, many very nice items get mounted onto layouts making them virtually impossible to remove w/o damage being probable. Having dismantled many layouts in the past, I have seen far too many great structures end up in dumpsters. Almost everything on my layout is very close to being readily removable.
cole7015
Re: on trainz site
Postby cole7015 » Fri Apr 20, 2018 6:34 pm
typical dum asses. If I was charging to fix this after the 1500 final bid add another 1000.
Bill Basden Delta Models www.deltamodelsusa.com :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Re: on trainz site
Postby robert. » Fri Apr 20, 2018 7:54 pm
It wont be repairable after trainz ships it in that box.
Re: on trainz site
Postby E7 » Fri Apr 20, 2018 10:45 pm
robert. wrote:It wont be repairable after trainz ships it in that box.
.....which might be the origin of the damage.
Re: on trainz site
Postby De Bruin » Fri Apr 20, 2018 11:03 pm
Rufous has this right. I can assure you the individuals that had to dismantle Joe's layout took great care in all matters regarding the structures, indeed many were installed as to be permanent and then the issue compounded by additional benchwork and structures getting crowded in.
The circumstance around dismantling a layout are often as unique as is the techniques and sequence with which it was constructed.
Just sayin', there's no 100% "happy ending" for anything but the rolling stock, and sometimes not even then.
LarryK
Re: on trainz site
Postby LarryK » Sat Apr 21, 2018 8:50 pm
Just looked at the item. May have some loose parts!??? What about all the damage?
Yikes!
Larry
No Comment!
Re: on trainz site
Postby robert. » Sat Apr 21, 2018 9:23 pm
what's the need to glue it to your layout.
Re: on trainz site
Postby Rufus T. Firefly » Sun Apr 22, 2018 10:20 am
robert. wrote:what's the need to glue it to your layout.
There is none yet almost all scenery materials are secured in some capacity if only to prevent their later "traveling" about....
Re: on trainz site
Postby up148 » Sun Apr 22, 2018 4:29 pm
Actually the box in the photo looks like the original OMI outer box and there should be the typical OMI green inner box with foam. If it was just shipped in the outer box, even with shipping peanuts, the legs, struts, columns will break loose. For it's size, it's a very delicate structure, so I believe the damage could have easily been done in shipping and not in removal. My bad.
Anything under $1000 will be a good buy and someone who is good with a soldering iron and has patience will have a $2000-2500 structure for a lot less $$$. There were only 25 built.
Re: on trainz site
Postby Rufus T. Firefly » Sun Apr 22, 2018 5:15 pm
up148 wrote:Anything under $1000 will be a good buy and someone who is good with a soldering iron and has patience.........
Anything under $1000 will be a good buy for someone who is good with a soldering iron and has patience.........and has an actual need for it. What this one is worth is whatever it actually sells for at the end of the listing. I can spare a nickel for it.
Re: on trainz site
Postby up148 » Mon Apr 23, 2018 9:52 am
Totally agree Martin. But they are very rare and if you're a UP modeler whose been coveting one of these models for decades (not me) it's a good opportunity and project.
I've seen these go for $3500 in pristine condition and actually sold one back in the late 90's (pristine model and boxes) for $3000, because I couldn't afford to keep it (I bought it in a collection of other models I did want).
So, we all have our druthers, but for the right guy this is a good model to go after.
Re: on trainz site
Postby Rufus T. Firefly » Mon Apr 23, 2018 10:21 am
up148 wrote:Totally agree Martin. But they are very rare and if you're a UP modeler whose been coveting one of these models for decades (not me) it's a good opportunity and project.
All true for the right guy, but it's not the 90's now. The seller hopes that there are at least 2 "right guys", :wink: :wink:
BTW, how many hours of work do you guesstimate might be involved in putting it to rights?
