Lobaugh drivers?
Lobaugh drivers?
I should be the last guy to ask: thinking about a very high drivered Pacific. Need one axle worth of Lobaugh 84" spoked - either heavy or light counterweight. Would not turn down a medium. Check your junk box?
Re: Lobaugh drivers?
Bob, any chance you could post photos? I have a accumulated a few random drivers but have no idea how to tell a Lobaugh from most any other.
Unless they've been worked on, Lobaughs are the ones that wobble and are out-of-round.
Heck, it's Friday Morning. Burner needs a good wake up. That should do it.
The only cast iron drivers that are "true" right off the bat are Lobaugh, so long as the keys are trimmed to fit. Here is a photo of what I have:
Note the 81" driver - I can use it, if nobody has a lonely Lobaugh axle pair. I would just make two new tires. You can see an ever so slight difference in the casting. I am just being lazy, and hoping to find a genuine Lobaugh mate.
The Lobaugh range from 1.765 to 1.78 in diameter over the tread. That kind of variance is not unusual, although I prefer them to be a bit closer. Crank pin throw is identical between the Lobaugh and Pearce - not always so fortuitous.
Just for kicks - in 17/64 scale the large Lobaugh drivers scale out to a hair over 80". The Pearce pair scales out to 77" - just right for a Harriman Light Pacific.
Also note the key ways - 45 degrees on Lobaugh, zero on the Pearce. Pearce had to cut the axles at 90 degrees.
This photo is in the Pacific thread, but thought it worthwhile to post here - those are 84" Lobaugh drivers.
bob turner wrote:The only cast iron drivers that are "true" right off the bat are Lobaugh, so long as the keys are trimmed to fit.
Valiant attempt to drag your carcass outta bed at a reasonable hour.....but you still stayed in bed for almost two hours after I put that up.
Oh, well.
Nobody disturbs me before 10 AM Pacific!
bob turner wrote:Nobody disturbs me before 10 AM Pacific!
But I did try.
Figured the one shot was the Low baw driver posting.
So after not trying any harder than that, I went through my spare driver tires and found exactly two that matched the 84” Lobaugh. Yesterday I cut the Pearce drivers, insulated one, and matched the set.
Figuring I was on a roll, I found four tires close to the Scale Craft Pacific, and converted a spare K4 mechanism to 2-rail, all flanged. Went a lot quicker than I remembered.
Most of the reason for this update: I ran out of green Loctite, and used red. Red is temporary, for screw threads - but so far, it looks like my driver tires will not soon fall off. I am surprised - I tried to move one tire with some shear force, and it wouldn’t budge. Gotta get some green or blue for the next step - quartering.
Unless Loctite changed their color chart Red is permanent and can only be removed with heating from a blow torch.
Users browsing this forum: No registered users and 50 guests
