Anyone care to discuss the pros and cons of decals versus dry transfers? I have seen quite a bit more information on decals/decaling, but not much the other way. Topics like longevity and suppliers and installation. Pretty sure the late John Clemons used only dry transfers, but I never got around to talking with him about the subject before he passed. I am sure there are arguments both ways.
I guess one of the first things is that decals might be a bit easier to find.
Decals versus Dry Transfers
Re: Decals versus Dry Transfers
I use either. I find it far easier to assemble lettering letter by letter using dry transfers. I also find that while I can greatly minimize decal edges, and avoid bubbles and silvered areas, etc., none of that happens with dry transfers.
Can I find decals - for what I am specifically looking for -- sometimes and maybe
Can I find dry transfers - - for what I am specifically looking for -- sometimes and maybe
I tend to let the decal or dry transfers that are available drive a project.
All excellent points. I know decals could be produced using an ALPS printer, anyone have any insights on the production of dry transfers? Sources? Longevity? (I know decals tend to "go south" after time).
I use both with equal enthusiasm. However I rather use Dry Transfers if I have the choice. Availability drives either product. I buy either in anticipation of future projects.
I have to think dry transfers can't be too difficult to print ; it is my impression after some
order correspondence with the fine folks at Clover House that they often print specific sets to order from master files,
hence their wonderfully "gi-normous"catalog and selection.
What I'm curious about is the specifics about the actual type of printer they employ.
Otherwise I agree with Rufous's comparative assessment and comments, likewise will add the following personal preferences
I use decals exclusively for car body striping, to allow for straightening up the application with a straight edge while its still wet.
I'll use either for heralds, lettering and road #s unless the surface has a lot of raised detail (like the sides of the long end of a Diesel Hood)
in which case it's decals due to their ability to stretch and cover.
I invariably go with dry transfers for scribed wood car bodies though I know that with proper finish prep decals can be applied successfully to same, still I'll only use decals on wood if I have no alternative as I am lazy in that regard.
As an aside, out of necessity I have learned that "decals" made on low end laser jet and desktop printer using clear medium "water slide" are not in fact decals, but literally printing on top of clear plastic medium and require a significantly different application technique than traditional decals. Generally I only use this kind of transfer for letter-boards, as the thickness of both the print application and clear medium preclude their application over significant raised detail.
Might want to talk to Tom, at Clover House. he can share some of the critical issues. One thing to keep in mind, dry transfers use a waxy, or maybe just a special wax, a regular printer or even an ALPs won't work.
