To hold bottom cover, gearbox bridge, cylinders, valve hanger and boiler.
They are #5. In my Half Zero Varney days I thought they were 5-32, but all I am finding is 5-40.
What are they before I start ordering stuff?
Varney Screws
Varney Screws
Re: Varney Screws
I found a set of instructions for the All Nation Atlantic in my files. If we assume it is built using the same drive components as the Varney Ten-Wheeler, then the screw size is #5-40:
Dave -- I will email you a scan of the instructions.
Re: Varney Screws
ah. So they are 5-40.
4-4-0 has less frame tie bars....ah ha.
Looks like the rest is similar if not the same.
I am guessing the 117 6-32 pair of screws is motor to mount.
Getting close. Gotta pull my #2 drivers off and set the crankpin for eccentric position, then screw it all together.
The boiler I have is lead. With a big lead slug inside. Had to clearance for the worm bridge.
Frame is lengthened 1/2" at the rear to accommodate.
Somehow the smokebox front is not with the main parts. On a search for another box of stuff.
Re: Varney Screws
I may have some 5-40s laying around, and will look for a boiler front.
Once you are sure you have drivers and pins the way you want them, I recommend Loctite. Glue those suckers in quarter!
Re: Varney Screws
bob turner wrote:I may have some 5-40s laying around, and will look for a boiler front.
oh, yeah. Planned on permanence.
Re: Varney Screws
Looking at a pristine boiler front and some 5-40 x 1/4" pan head slotted screws. Need a mailing address - PM.
Re: Varney Screws
PM'd away.
Jimmy..from the attachments, looks like frame rails and braces to be assembled. Hammer. Yet the two I have here look....different than hammered. Recessed.
Instructions don't say to screw the lower cover on to keep the holed lined up first. No wonder they aren't!
Re: Varney Screws
arrrrggghhhhh.
Had a broken eccentric crank. No problem, I have two new Babbitt ones.
Got the old one mounted, rod screwed to it with the shouldered screw. Great.
Got the new one mounted, screw falls through the hole (threaded hole).
Dug around in the cigar box full of bags of parts, and found two slot head, shouldered screws that fit the hole in the crank and in the rod. One in this new crank, the other installed in the spare crank so it's there and I don't have to do this again.
Apparently, somewhere along the line, they changed that size.
Of course, we all got that bulletin, right?
Oh, and the hole in the crank to fit onto #2 crankpin was too small but just a little....rattail fixed that.
Re: Varney Screws
Fun is finding out they were epoxied in. Now THAT was fun getting apart. But I did, and no broken or stripped bits.
