Global Cooling ??
Global Cooling ??
Postby HONDO74 » Fri Nov 16, 2018 7:32 pm
Here we go again......
NASA warns long cold winter could hit space in months bringing record low temperatures
https://www.foxnews.com/science/nasa-wa ... mperatures
A long cold winter could hit space in months bringing record low temperatures, NASA has warned.
That's the warning from a scientist who fears sunspot activity on the surface of our star has dropped so low that record low temperatures could soon set in.
“We see a cooling trend,” says Martin Mlynczak of NASA’s Langley Research Center.
“High above Earth’s surface, near the edge of space, our atmosphere is losing heat energy.
"If current trends continue, it could soon set a Space Age record for cold.”
Solar minimum can enhance the effects of space weather, disrupt communications and navigation, and even cause space junk to "hang around", NASA said.
Mlynczak and his colleagues have recently introduced the "Thermosphere Climate Index" (TCI), which measure how much heat nitric oxide (NO) molecules are dumping into space.
The results come from the SABER instrument onboard NASA’s TIMED satellite, that monitor infrared emissions from carbon dioxide (CO2) and nitric oxide (NO).
By measuring the infrared glow of these molecules, SABER can assess the thermal state of gas at the very top of the atmosphere – a layer researchers call “the thermosphere.”
When the thermosphere cools, it shrinks, making the radius of the Earth's atmosphere smaller.
This means it can delay the natural decay of space junk, resulting in a more cluttered environment around Earth.
“Right now, it is very low indeed,” Mlynczak told Space Weather.
“SABER is currently measuring 33 billion Watts of infrared power from NO. That’s 10 times smaller than we see during more active phases of the solar cycle.”
“The thermosphere always cools off during Solar Minimum. It’s one of the most important ways the solar cycle affects our planet,” explains Mlynczak.
“We’re not there quite yet,” he said of the record cold, “but it could happen in a matter of months."
The most famous example of a prolonged sunspot minimum is the Maunder Minimum, referring to a period around 1645 to 1715 during which sunspots become exceedingly rare.
Maunder coincided with the middle part of the Little Ice Age, when Europe and North America experienced colder temperatures - fuelling speculation that the two were connected.
Re: Global Cooling ??
Postby E7 » Fri Nov 16, 2018 7:44 pm
HONDO74 wrote:Here we go again......
I don't know how that could possibly happen considering all the HOT AIR expelled by the Global Warming Nuts! :mrgreen:
Postby Rufus T. Firefly » Fri Nov 16, 2018 8:06 pm
Easily. Just look at our international relations/State Dept - as cold there as the back side of Pluto.
Postby E7 » Sat Nov 17, 2018 8:00 pm
Benghazi
Postby Rufus T. Firefly » Sat Nov 17, 2018 8:59 pm
Make a list 50 years long and list every international fiasco you can; there's got to be at least a dozen for every year or more. The ineptitude factor is impressive and uniform.
John Webster
Postby John Webster » Sun Nov 18, 2018 3:40 am
I'm currently reading A Cold Welcome by Sam White in which he maintains that the difficulties the early European settlers of North America experienced were related to the Little Ice Age. One piece of evidence he cites is a letter from a missionary priest complaining about walking barefoot in 18" of snow. The priest was in St. Augustine, Florida in the 1590s.
In contrast to that, wine exports from the north of England to France in the 1200s were so disruptive to the French economy that the two nations almost went to war. It is too cold to grow wine grapes in northern England today.
Users browsing this forum: No registered users and 86 guests
