Anyone know who manufactured these?
https://www.ebay.com/itm/O-Scale-On3-On ... fresh=true
Table lamps
- rex desilets
Table lamps
Re: Table lamps
Walthers....then Keil-line.....now Scale City Designs
- rex desilets
Re: Table lamps
Thanks! Never thought to look there.
If one were to recast these in a clear plastic so as to light them, what would your recommendation for a resin be?
Re: Table lamps
Rufus T. Firefly wrote:Walthers....then Keil-line.....now Scale City Designs
Keil LIne is now owned by Scale City.
Re: Table lamps
E7 wrote:Rufus T. Firefly wrote:Walthers....then Keil-line.....now Scale City Designs
That's why I wrote now Scale City Designs,
Miapoxy(Freemans) makes a clear resin that I've never had a good excuse to test. Recasting for your personal use is generally considered acceptable albeit technically not.
Re: Table lamps
Rufus T. Firefly wrote:That's why I wrote now Scale City Designs,![]()
I was bedazzled by that beauty??? in you avatar and did not see the "now"!
Re: Table lamps
E7 wrote:Rufus T. Firefly wrote:That's why I wrote now Scale City Designs,![]()
Happy Easter!
- rex desilets
Re: Table lamps
Aware of that. If the miniature lamps were available in a clear plastic, I'd order them..Rufus T. Firefly wrote:<snip>If one were to recast these in a clear plastic so as to light them, what would your recommendation for a resin be?
Re: Table lamps
rex desilets wrote:Aware of that. If the miniature lamps were available in a clear plastic, I'd order them..Rufus T. Firefly wrote:<snip>If one were to recast these in a clear plastic so as to light them, what would your recommendation for a resin be?
Call Scale City and ask them to cast them in clear resin? Berkshire Valley also had some lamps, but last I looked still solid castings, but I think available pre-painted.
- rex desilets
Re: Table lamps
I'll contact Scale City. I doubt, however, that,as I suspect, their metal casting process would be compatible with resin casting. Still, interesting idea.Rufus T. Firefly wrote:<snip>
Call Scale City and ask them to cast them in clear resin? <snip>
Re: Table lamps
rex desilets wrote:I'll contact Scale City. I doubt, however, that,as I suspect, their metal casting process would be compatible with resin casting. Still, interesting idea.Rufus T. Firefly wrote:<snip>
Pretty sure that they do some resin casting work; spin cast molds will work with resin, but whether they will or not do it is something else entirely.
