And so when I see a thread like this and I just shake my head.
https://ogrforum.ogaugerr.com/topic/pro ... 9129616341
Roy wrote:Why mess with command control at all?
G3750 wrote:*Finer granularity (speed steps) control over your locomotives. There is a real difference between working a lever and the kind of fine speed control possible with TMCC, Legacy, or DCS (when it works). DCS has something called Scale MPH, which is a brilliant concept. It allows locomotives of different types to run as a consist. Legacy has something similar. TMCC supports consists of identical locomotive types.
G3750 wrote:*Individual control of locomotives without the use of isolated blocks. In a command system, you individually control the locomotive, not the track voltage. Someone can be switching cars in a yard while you are running a mainline train. And with a Block Power Controller, I can control power to individual blocks on the layout. I can turn off yards or sidings with a button.
G3750 wrote:*Simplified wiring. Conventional block control requires more complicated wiring with toggle switches for each block. Command control allows me to eliminate the control panel.
G3750 wrote:*Better control of accessories. With TMCC, a component called an accessory motor controller (AMC) can provide finer grained control of accessories than is possible conventionally. The accessory will operate better (more smoothly).
G3750 wrote:Most people who experience [command control] will not go back to conventional control.
We can't help people with command control hardware problems, other than to give them an address to send their circuit boards to.
G3750 wrote:TMCC, for me, is the "go-to" command control system....it holds the advantage over Legacy in terms of signal strength and reliability.
chuck wrote:I only have one Legacy loco and I use almost none of the advanced features. I do find that the rest of my TMCC engines run way better with the Legacy remote than they do with the CAB-1.
There is a tremendous irony that the LCRU's installed since day one of their release have run in crippleware mode until the release of Legacy (unless you installed a computer interface). The engines all run in CAB-1 mode (aka relative speed steps) because the CAB-1 can't do anything else. Odyssey-1 engines can run smoothly in TMCC mode and have 256 speed steps. They run like crap in CAB-1 mode. An updated CAB-1 (with full TMCC support) should have been released around the time DCS was announced. It would have addressed most of performance issues while keeping the KISS aspects of TMCC.
Roy wrote:G3750 wrote:TMCC, for me, is the "go-to" command control system....it holds the advantage over Legacy in terms of signal strength and reliability.
Why is that?
