https://www.ebay.com/itm/Lionel-Postwar ... 2697625829
Right over the paint nicks, chips and scratches.
The puzzling thing is the (apparently) pristine side, main and eccentric rods, with the upper valve gear rusty (RH side) AND the "decor" wires rusted (boiler handrails).
Did someone remove, wire brush, clear the parts and not do them all?
$70 + $20 to ship with no bid option and no tender....uh, no.
ArmorAll!
Re: ArmorAll!
Wrong trailing truck. Does not have the Baldwin drivers. Boy does it shine!
Re: ArmorAll!
"Variation F: This variation’s most notable feature is that it has spoked drivers instead of the Baldwin discs featured on all of the other variations. Issued during the Korean War when magnetic material was at a premium, this locomotive does not have Magnetraction. It also has the redesigned pilot with simulated coupler, black steel motor frame sides instead of non-magnetic aluminum, BLACK painted smoke stack that was a separate piece, a sheet metal two axle trailing truck, and a RED and GOLD keystone decal on the boiler front that is numbered "5690". Came with a No. 6466W tender with staple-end trucks that had one magnetic coupler. (1952)"
https://www.tandem-associates.com/lione ... 5_loco.htm
Re: ArmorAll!
Yes, but it doesn't explain the wrong trailing truck.
And those drivers are ugly. Never liked them on any locomotive. They really do make the engine look like a toy.
Re: ArmorAll!
I always hated those 4 wheel cheapie trailing trucks. Had several engines that came with them, got proper 2 wheel trucks and fixed them. I still have a couple of the 4-wheel units in a box.
Didn't like the change to the cast in dummy coupler on the nose, either. Swap the cylinder block or grind it off.
Some I left, but my coupler conversions have to cut through it anyway.
Never liked the high headlight smokebox fronts. All mine were changed to center headlights almost before the 225E boiler conversions.
Re: ArmorAll!
Just goes to show you. Postwar prices have not tanked. It's grading standards that have tanked.
John Long
Re: ArmorAll!
Now that's priceless! LOL
Re: ArmorAll!
jlong wrote:Just goes to show you. Postwar prices have not tanked. It's grading standards that have tanked.
Ahhh. That's it!.
Re: ArmorAll!
Seller included his phone number in the photos -- that's a sign that he's probably willing to sell it for less if you negotiate a deal with him directly, off of feebay.
Re: ArmorAll!
Chris Webster wrote:jlong wrote:Just goes to show you. Postwar prices have not tanked. It's grading standards that have tanked.
Might also be a sign that he's really lonely and wants lots of robocalls...........
Users browsing this forum: webenda and 28 guests
