Kit question
Re: Kit question
Never seen that one before nor have I heard of that company.
Looks like something fun to build!
Re: Kit question
Google has some hits about the companies kits. They appear to be mostly HO but they did produce some 1/4" scale building kits. One was a "re-issue" in 1981.
I just checked some back issues of RMC and MR going back to the 1960's through the 1980's. They were not big enough to be a direct advertiser and I don't have a big enough sample to say they weren't advertised within an old mail order's listings. I don't have the magazine indexes so I can't search that way either (maybe a kit review or a product announcement). One "auction" site classifies these as "old school craftsman kits" with lots of small detail parts that just rattled around inside the box (no special bagging). This was their way of saying that the kits probably have missing parts. They went on to say that they had acquired this stuff mostly from "estate" sales. Caveat Emptor.
Re: Kit question
Thank you for that Chuck,
I did discover an HO kit listed below with 1981 re issue. So maybe 40+ years old. I find this kit to be quite nice with detailed instructions, several detailed elevations combined with everything bagged neatly.
What caught be by surprise, not being an experienced kit builder was the cutting of parts that you find pre cut in today’s kits. For instance, all the walls had to be cut to size and shape along with the window and door openings. So far so good. They have a PO Box in case I need replacement parts all I have to do is return the ones I mess up
combo duplicate remover
Re: Kit question
gregj410 wrote:What caught be by surprise, not being an experienced kit builder was the cutting of parts that you find pre cut in today’s kits. For instance, all the walls had to be cut to size and shape along with the window and door openings.
Once upon a time all kits were like that and just a step or 3 above scratchbuilding.
More fun and more versatile as you could relocate windows and doors a lot easier then vs. more modern laser cut kits where you're just following instructions to build the same structure that everyone else will have on their layout.
Re: Kit question
Laser cutters are making these type of kits much easier to build, at least in some ways. They can now use sturdier materials like 3 and 5 ply plywood. I think they build up nicer than the CNC routed Masonite. Definitely easier to paint/decorate than Masonite
Re: Kit question
Rufus T. Firefly wrote:gregj410 wrote:What caught be by surprise, not being an experienced kit builder was the cutting of parts that you find pre cut in today’s kits. For instance, all the walls had to be cut to size and shape along with the window and door openings.
Picked these up some time ago. Really cool original buildings in HO plans. Should be easy enough to scale up to O. Hopefully with enough experience I’ll be able to get a lumber take off and figure out windows, doors, etc. Excited to eventually build some one of a kinds.
Re: Kit question
Not sure how well the tools work with O scale but with HO craftsman structure kits, the NWSL True Sander and Chopper were the cat's meow. The True Sander in particular for squaring up walls.
John Long
Re: Kit question
I use a Chopper all the time when I need many of the same length bits of stripwood up maybe 3" scale thick.
Sander - regular sandpaper stapled to a 2" x 4" block.
I've been looking for a copy of that Harrington book on wood structure for quite a while - always seems to be on the pricey side.
Re: Kit question
https://www.ebay.com/itm/154051179921
Re: Kit question
gregj410 wrote:I've been looking for a copy of that Harrington book on wood structure for quite a while - always seems to be on the pricey side.
Exactly.....
Users browsing this forum: No registered users and 49 guests
