Weekend Photos - August 2021
Postby healey36 » Sat Aug 07, 2021 11:37 am
I can't remember if I've posted pics of this before, but I've been clearing away some of the accumulated stuff from my office and this old Handlan lamp turned up in a dusty corner, nearly forgotten:
Seven or eight years ago, my wife and daughter found this at an estate sale just a couple blocks from our house. Embossed with the PRR keystone, it was in pretty rough shape. The lady of the house had removed the lamp pot and globe and used it for a hanging planter on her back porch. Needless to say, many years of being filled with dirt and liberally watered had rotted out nearly all of the 3-1/2 inch diameter underside. My inclination was to just chuck it, but my daughter thought it could be semi-repaired, so we made a bit of an effort.
I cut out the badly corroded bottom and, without much luck, was looking for some sort of galvanized end-cap or metal that we could use to fashion a new bottom. Fabricating a new underside from sheet stock wasn't going to be easy. We soon discovered, however, that the plastic lid from a 40-oz. peanut-butter jar fit nearly perfectly. A bit of wire-brushing, a shot of flat-black paint, and a couple dabs of Loctite Power-Grab had the replacement "bottom" in place.
A replacement globe proved easier to find than I'd anticipated. A visit to a local lighting store turned up nothing that would fit, but they directed us to W. T. Kirkman of Ramona, California, which is a pretty great resource for these sorts of things. We quickly found a reproduction globe and sent off an order. I seem to remember that they offered it in red, green, and clear glass (we chose red).
So then the problem was how to light it. It originally had a kerosene lamp in it with a key to raise the wick as required, but we couldn't find any sort of oil lamp that would fit properly. I think Kirkman sold something that might have worked, but I didn't really want to mess with kerosene and the related mess. We moved on to trying to find a small cordless electric light that might fit. We stumbled on this small camp lantern at Walmart made by Ozark Trail that fit nearly perfectly. A four-LED configuration, two brightness settings, requiring three AA cells, you just need to open the lamp, turn it on, slide it back down, and you're on your way. I've actually used this thing a few times when walking the dog(s) in the dark during winter. It can be a bit zen-like when snow's falling.
Working on the roof for Parlor Flats while trying to date a Flyer set that turned up recently. My library of Flyer catalogs stops in 1937, but this set looks like it's probably 1938 or 1939. It has those curly-que couplers, which I seem to recall had a short run just before the war. Should know more soon.
Here's a link to W. T. Kirkman if you're looking for lantern bits:
https://lanternnet.com/
Re: Weekend Photos - August 2021
Postby HONDO74 » Sat Aug 07, 2021 3:54 pm
healey36 wrote:Working on the roof for Parlor Flats while trying to date a Flyer set that turned up recently. My library of Flyer catalogs stops in 1937, but this set looks like it's probably 1938 or 1939. It has those curly-que couplers, which I seem to recall had a short run just before the war. Should know more soon.
I have 38,39,40 and 41 in digital plus 46 to 65. I can burn them to a CD and sent them to you. :)
Postby healey36 » Sat Aug 07, 2021 5:08 pm
Wow, if you have '38 thru '41, that would be super handy. That would tie off the last of the prewar O-gauge for me. For whatever reason, I've got nothing after Gilbert took over.
I'll PM you.
Postby chuck » Sat Aug 07, 2021 7:36 pm
Nice job on the lantern!
Postby healey36 » Sun Aug 08, 2021 8:47 am
Thanks!
I often wondered if the thick black paint was original. A few years back I found another one in an indoor flea market in western New York. It was of similar design, embossed N&W, and had the same heavy coat of black paint on it. Based on that, I'm assuming the PRR lantern's paint is original (except for the black-painted plastic peanut-butter jar lid).
I used to know a guy up in Frostburg, Maryland, many years ago, who was an avid collector of these things. He was a former mayor of the town and owner of a small hardware store. He had a couple hundred lanterns, most of them piled up in the front window of his old store front. Most of the ones in his collection were similar in design but painted a dull steel or gun-metal color (not silver).
Jim K
Postby Jim K » Sun Aug 15, 2021 8:17 pm
A Corgi Brill retrofitted with a Bowser motor..............
https://www.youtube.com/watch?v=QUaSoht9BGw
Jim K
Postby J. S. Bach » Mon Aug 16, 2021 6:24 pm
Nice. I have two of those Baltimore Birneys; one is fitted with a decent running home-built power truck and the other will get the Wagner truck that I got for it.
Postby healey36 » Mon Aug 16, 2021 7:31 pm
Love seeing the traction gear, especially when it's running under the wire (even if in this case its drawing from the third rail). Nice smooth runner. I have a Bowser "tinplate" Birney here that I acquired thinking I'd use it as a donor to motorize a Paya tin repro. It was too wide to fit, so a friend of mine flipped me a Marx unit to try instead. That's an unfinished project, as I nearly destroyed the Paya while trying to cut the bottom out for the motor. That project is going to require some real work, not the least of which being a reinforced underside.
Parlor Flats (to be renamed) is nearly complete:
Nothing spectacular here, for sure. Cut the roof from some matt board using the plan dimensions, adjusted slightly. Tried to paper it for a tarpaper look using some cardstock, some black satin sprat paint, then an overspray of clear matte. Again, I don't get a nice flat finish with the Krylon, but here I don't really care as I want a toy/tin building look, not so much a scale rendition (not sure I could pull that off anyway). The Old Man would have used a sheet of sandpaper instead of cardstock, giving it a bit of grit in the finish. I cut a small piece of wood for a chimney, covered it with some brick-paper. The plan called for the chimney on the peak, but I moved it down from the peak toward the back. Looks kinda tall to me.
I started working on fashioning a tinplate-style semaphore last night. Should be pretty simple, but the sheet aluminum I was going to use feels a bit flimsy. Might need to increase the gauge or try something cut from some sheet steel I have out in the garage. Not sure if I want to mount it on the platform or just behind. We'll see.
Postby sarge » Tue Aug 17, 2021 6:25 am
You could always put an old Lionel (or other) operating semaphore, the older the better for your purposes, off the end opposite the baggage door and ramp, then neatly nest a pushbutton inside that angle made by the ramp and platform.
It would have the tinplate style, anyway. I can hook you up with a PW one and a pushbutton out of my stash of such things.
BTW, on hand lanterns, the finish as they came from Adams and Westlake or Dietz was unpainted. Lots of folks painted them when they electrified them since they would leave them out in the weather on a pole or something.
Postby healey36 » Tue Aug 17, 2021 12:11 pm
That's a good idea, although I want something that looks a bit older, a bit smaller, perhaps akin to this prewar JEP station/signal which is quite simple:
I have a couple of the Lionel 151 semaphores which I've used with insulated sections, but they don't seem to work very well for me. If I run them off track power, there doesn't seem to be enough current to get them to move properly, and if I wire them to a fixed post, they snap rather violently.
I've seen a few Hornby and Bing signals on eBay, but they seem to go for big money, even the broken ones. I have a prewar Hornby that someone partially repaired (incorrectly) which I like the look of.
Most of the lanterns I've seen are a steel color, although some have this thick black paint on them. I never paid enough attention to see if they were a painted steel color or just bare metal. Some that you see have a healthy coating of rust on them, so being left unpainted would seem likely.
Postby sarge » Wed Aug 18, 2021 5:54 am
I’d bet we could make something of the 151 mechanism, reshape the blade to something cool but a tip o’ the trilby to a US “train-order” blade. Got the metal shop here to do it.
Otherwise, perhaps simplest would be a ball signal. Easily crafted from wood, a piece of tube, some thread, and a big bead; coolness goes off the chart.
Postby healey36 » Wed Aug 18, 2021 7:21 am
We think a lot alike...I was just looking at ball-signal photos yesterday with an eye toward that possibility:
I seem to recall Andre over at River Leaf makes a nice kit for one.
Postby sarge » Wed Aug 18, 2021 9:24 am
This was a common train-order ball signal. Some railroads in New England used white for the ball and lantern to distinguish between a train-order board at a station and a red ball for a block signal.
If the ball was lowered into the tube that obscured it, there was no call to stop and accept a train order. Hoisted up and visible meant a train-order was to be issued to whatever train the signal was set against.
You could lower the ball through the tube to maintain the lantern.
I’d bet a lantern could be had at a craft store in the dollhouse bits along with a big bead for the ball. I have some silk surgical thread, we can solder up out of brass bits what we need for the tube here, pulleys might be an R/C hobby store item, and I have springs.
Postby Rufus T. Firefly » Wed Aug 18, 2021 9:41 am
healey36 wrote:I seem to recall Andre over at River Leaf makes a nice kit for one.
He does or did; got one on my layout - not sure he's producing anything now.
Postby healey36 » Wed Aug 18, 2021 10:07 am
Sounds like a fun project. I'll start looking around for the bits.
Users browsing this forum: No registered users and 19 guests
