Does anyone have an idea who made the following and the importer?
https://www.ebay.com/itm/403828979418?h ... Swtp9i9cmB
Larry
Ebay item
Re: Ebay item
Sunset. Probably 3rd Rail. ONLY Clinchfield Challenger with that road number I can find, note what appears to be NWSL gearboxes, altho probably Asian copies.
Re: Ebay item
Was thinking Sunset, but possibly Williams. Detail level and tender truck assembly.....
Re: Ebay item
LarryK wrote:Does anyone have an idea who made the following and the importer?
Larry
The funny part is the claim it's the most detailed engine he's ever seen.
"The most heavily detailed Train I ever had the amount of detail is amazing what a model not sure if it works my opinion should be displayed sold as is any questions please ask was displayed so selling as not tested "
It's not. In fact first glance I thought 2-rail MTH. Had to run cab numbers down. And that is assuming nobody re-numbered it.
Typical CYA..not sure if it runs, if it works, should be displayed, as-is, not tested.
7 bidders at $202. Good if folks don't get stupid and try to prove "it's worth what it sells for".
The picture of the label is puzzling. No brand or part number.
BTW, to keep evilbait from tracking views....just copy off everything from the left of the question mark.
Depending on your search, the URL can be 4 or 5 lines long..shows them what you're looking at. Example:
You may not care, folks who spout current wisdom may not care..but I like to limit their abilities towards ME.
Re: Ebay item
This is a Sunset 3rd Rail Allegheny. Note the gearbox that looks like NWSL but is cast:
https://i0.wp.com/oscaledeadrail.com/wp ... C768&ssl=1
Re: Ebay item
Rufus T. Firefly wrote:Was thinking Sunset, but possibly Williams. Detail level and tender truck assembly.....
I would have guessed Williams, but I don't really know so I did a quick search. I found this old auction listing for a 3-rail Williams UP Challenger on Invaluable - Lot 102: Williams Crown Edition O scale brass Union Pacific 4-6-6-4 Challenger in OB
Also see this picture of the underbody - it looks to me like the gearboxes, screw types and locations all seem to match the Clinchfield 2-rail version on ebay.... so I'm thinking they both came from the same builder.
Re: Ebay item
Does sunset number all their locos? Mine have a number plate on the bottom( 123 of 300) i only have their 3 rail stuff.
Re: Ebay item
Without really studying:
Williams seems slightly small to me, but the tell-tale is the handrail with inset tube just above the cab windows on the curve of the roof. Williams did not model it; Sunset did.
steamaheadstephen59
Re: Ebay item
Is a Williams, there are a few tells. I must say I prefer the black to the usual grey that williams Challengers turn up in.
Users browsing this forum: No registered users and 58 guests
