Hi Gang! Question!!!
Postby 2railjon » Thu Nov 17, 2022 2:24 pm
Hi All!! After taking a brief absence from model railroading I’m slowly getting back into it. I recently bought an MTH PS2 with Scale wheels that says it 2 Rail / 3Rail conversion capable but no where in the instruction manual does it say how to convert it. Any ideas?? Please see pic’s and thanks for any help!
I have another MTH engine where it says remove the roller pick-ups then flip the switch from 3 to 2 rail. I removed the pick ups but don’t see any 2/3 rail switch. Just an unmarked switch under the engine cab.
https://hosting.photobucket.com/images/ ... 269E9.jpeg
https://hosting.photobucket.com/images/ ... 768EF.jpeg
Re: Hi Gang! Question!!!
Postby E7 » Thu Nov 17, 2022 2:50 pm
Welcome back Jon,
I have never owned any of the convertible stuff, but from all I've read, all you should have to do is mount the scale wheels and throw a switch on the bottom of the engine.
Guessing that unmarked switch is what you need to throw.
Here is a link to MTH service center:
https://www.mthtrains.com/service
Postby 2railjon » Thu Nov 17, 2022 4:57 pm
Great to hear from you, Rich!!! The box says it has scale wheels so I shouldn’t have to replace them. I pulled the pick ups and flipped the unmarked switch after putting power to the outside rails. I got nothing. Put the pick ups back on and hooked power to the inner rail and one outer rail on the roller test base and it fired right up. Something’s screwy.
https://hosting.photobucket.com/images/ ... E5080.jpeg
Postby E7 » Thu Nov 17, 2022 5:08 pm
Jon,
Not sure how fond you are of the OGR forum, but I think it's a pretty good bet people over there could help you. MTH (or what's left of it) maintains a presence over there. That's where that link in my message above was copied from.
Good to have you back!
Postby De Bruin » Thu Nov 17, 2022 7:33 pm
Welcome back Jon, we were wondering what happened, certainly glad you're back on here.
Postby ScaleCraft » Thu Nov 17, 2022 8:07 pm
Lots of commentary on OGeR NK.
https://ogrforum.ogaugerr.com/topic/mth ... rail-track
Apparently, engine pickups for 2-rail suck. Some folks over there have done all sorts of things to try to get them to work.
http://i175.photobucket.com/albums/w141 ... 9c77ce.jpg
Shows switch actually marked. My guess is that's under the tender, with the truck limit chains shown.
Postby 2railjon » Thu Nov 17, 2022 8:08 pm
Thanks, De Bruin!!! Good to be back!!! :D
Postby 2railjon » Thu Nov 17, 2022 8:11 pm
Cool, Scalecraft!! I’ll get back on the issue tomorrow. It’s officially cocktail hour now!! :mrgreen: :mrgreen:
Postby bob turner » Thu Nov 17, 2022 8:24 pm
Yes! You were missed!
MTH steamers have drivers insulated at the axle, with necessary insulation on rods, etc. Shame, since the Koreans could have easily rim-iinsulated them for the same cost. They are also not standard-wired - insulation is on the right side of the locomotive.
My cure was to replace the frame, cylinders, and drivers. Made a much better model. Keep your eyes peeled for good Sunset and USH models - usually ready to go 2-rail.
Delighted you are back.
Postby 2railjon » Fri Nov 18, 2022 4:44 am
Hi Bob!! Great to be back and enjoying the problem solving that comes with the hobby! :mrgreen: now that you mention it I do recall the drivers are insulated at the axles.
Postby 2railjon » Fri Nov 18, 2022 2:33 pm
LOL!! There is nothing 2 Rail conversion compatible about this engine :lol: :lol: I’m thinking Trainz got suckered into buying a 3 Rail PS2 engine in the wrong box with me getting suckered into buying it. I do have the option to return it for a refund but then again I don’t have an engine to run under this year’s Christmas tree.
:mrgreen: And I’m not running any of my high dollar brass ones with 3 puppies and 3 kittens in the house. :lol:
Chris Rock
Postby Chris Rock » Sat Nov 19, 2022 6:15 pm
I was wondering recently what happened to you. Welcome back.
Postby J. S. Bach » Sun Nov 20, 2022 5:18 pm
Same here. Welcome back!
