My six-pack of coal cars from Menards has one car that keeps uncoupling.
Here, that one car has uncoupled, and the Lionel engine uncoupled immediately after.
bluelinec4 wrote:Lionel, Williams, MTH , RMT and Menards all like to deposit cars all around the layout
Norton wrote:So the wedge trick worked? Pete
sarge wrote:Why not cut the trip pin off flush with the upper surface of the lever, drill and tap 1/72 or 0/80 (or whatever is appropriate based on the diameter of the pin you cut off), then you've replaced the pin with a screw driven up in deep enough to catch the knuckle reliably. If the springiness of the lever underneath changes over time, you can adjust it with a jewellers' screwdriver.
An adjustable metal trip-pin.
Users browsing this forum: No registered users and 41 guests
