Finally good spray paint at a 20th century price
SWrailroader
Postby SWrailroader » Sat Jul 11, 2026 7:16 am
Bob T mentioned Quick Color flat black in one of his post. Found some at Home Depot, aka The Despot, for $2.98. At that price I had to experiment. It is an enamel. I sprayed it on bare brass, Taniya primed brass, and scale coat painted brass. Absolutely no Orange peel on any of the pieces and it was a true flat. Adherence on bare brass was OK, but excellent on the other pieces. Drying time to handle was 20 minutes, bear in mind outside temp in the 90s. Went on well in this god forsaken Texas humidity. Hand painted Future/Pledge glosss acrylic without a problem.
Discovered Quick Color gloss black as well. Sprayed it on Tamiya primed brass. The finish is a very high gloss akin to Scalecoat gloss black. Drying time seems much longer. 11 hours later and still some fumes. I have not tried to bake it yet.
Per the Despot website there is are other colors, I have seen only black at the store. Reminds of the Model T, you can have any color as long as it is black.
Re: Finally good spray paint at a 20th century price
Postby up148 » Sat Jul 11, 2026 8:43 am
Thanks for that information. You never know where you'll find good paint and with the cost of the "known" paints this is refreshing.
Postby Rufus T. Firefly » Sun Jul 12, 2026 11:53 am
SWrailroader wrote:Quick Color flat black
I will have to look for it next I have a need to wander over to HD.
Postby up148 » Sun Jul 12, 2026 4:06 pm
I'm needing some rattle can Harbor Mist Gray and searches haven't turned any up. I've got a can that is 20-25 years old and haven't tested it, but I need to paint some P&D brass trucks. Maybe brass trucks would be a good time to learn how to use jar paint and an air brush. :D
Postby up148 » Mon Jul 13, 2026 11:18 am
Little gray cells started working and I remembered I once bought a can of Harbor Mist Gray. So, started digging and found I have an almost new spray can of Scale coat 1 Harbor Mist Gray. I think this project is supposed to happen. :lol:
Postby E7 » Fri Jul 24, 2026 3:39 pm
up148 wrote:Little gray cells started working and I remembered I once bought a can of Harbor Mist Gray. So, started digging and found I have an almost new spray can of Scale coat 1 Harbor Mist Gray. I think this project is supposed to happen. :lol:
You know what they say Butch: There are 3 signs of old age: The first is loss of memory, and I forget the other two! :wink:
Postby up148 » Fri Jul 24, 2026 5:35 pm
Yeah, that gets more true every day. :D
Postby Rufus T. Firefly » Mon Jul 27, 2026 10:55 am
up148 wrote:......new spray can of Scale coat 1 ..........
Might be a can full of liquid gold, :mrgreen:
Postby up148 » Tue Jul 28, 2026 9:52 am
It will be if it stills works......I've got everything crossed that it will.
Postby Rufus T. Firefly » Wed Jul 29, 2026 7:41 am
up148 wrote:It will be if it stills works......I've got everything crossed that it will.
Best of luck on it - I've found these old spray cans of Scale coat to be pretty long lived. But I'm about out of them myself now.....1-3 more projects and they'll all be gone off the shelf.
